transmission swap for f150
Old Jun 4, 2009 | 07:14 PM
fordf150-13's Avatar
Default transmission swap for f150
Ok i have a 1997 f-150 2wd with the 4.6 liter but it needs a new transmission and i found a 1994 ford thunderbird for cheap and it comes with the 4.6 liter engine. I was wondering if i could take the transmission out of the thunderbird and put it on my f-150, is that possibe?
Old Nov 30, 2012 | 06:29 AM
fordboy94's Avatar
From my understanding, since there both gas engines. You should only have to count bell housing bolts and /or pan bolts. Yet that in and as its self can get tricky, due to electronics.
Old Nov 30, 2012 | 09:03 AM
greasemark's Avatar
If it's the same 4R70W trans, it should work fine. The electronics are the same, as is the logic. However, some of the trucks from this generation were equipped with the E4OD trans, which is bigger and has a different connector, cooler lines, etc, etc.
supermac
Mar 24, 2017 08:04 AM
danowens
Nov 14, 2006 10:59 AM
guyzie123
Aug 21, 2006 06:38 PM
fordgirl2
Oct 26, 2005 03:41 PM
farout_one
Jun 30, 2005 09:31 PM
