Help troubleshooting driverside front end issue
Old Jun 9, 2009 | 08:13 PM
m_jones1000's Avatar
Default Help troubleshooting driverside front end issue
I have a 04 ford f-150 4x4. I have noticed a noise in the front end that sounds like you have a bad tire. I have replaced al four tires and still of the noise. I am trying to narrow it down but have run out of ideas as to what it could be. There is no more than normal play in setering wheel. The noise gets louder when I turn the wheel to the left. Any ideas would be greatly apperciated!
Old Jun 10, 2009 | 12:59 PM
Bullitt94's Avatar
Are you talking about a clunking sound? Check to make sure your brake calipers and pads are tightened and seated properly.
Old Jun 10, 2009 | 06:54 PM
I think you may be on to something. I dont think I started noticing the noise until after I chaged the front pads. Thanks for the advice
Old Jun 11, 2009 | 09:14 AM
Bullitt94's Avatar
Hope it helps. Good luck.
Old Jun 16, 2009 | 09:31 AM
XMKTech's Avatar
If the sound is a roaring noise that sounds like a chopped tire and gets louder when you turn i think you are a victom of a bad wheel bearing. When a wheel bearing goes out you get a grinding or humming noise witch will increase or decrease while turing to the opposing side. Jack the truck up and leave in N put it is 2 wheel drive and spin the wheel and listen for a roar.. Also could be a bad CV joint. The joint soes not have to be leaking grease or have to grease to cause a noise.
Old Dec 4, 2009 | 08:18 PM
Norman Ray's Avatar
My 1989 ford bronco has a roaring noise that seems to be coming from the front end. It gets louder the faster you go with a small viberation also. When going throug a curve to the left it almost makes a scrubing sound.
Old Dec 6, 2009 | 11:03 AM
Bullitt94's Avatar
Sounds like you may have a wheel bearing going bad.
riccony
Dec 7, 2018 10:25 AM
digital_diversion
Jun 20, 2013 09:10 PM
Nick Greenfield
Apr 18, 2013 04:39 AM
QuickSilver
Jul 14, 2009 04:18 AM
Johnny Faster
Aug 27, 2007 06:13 AM
