cant shift
Old Jun 10, 2009 | 06:35 PM
gargoyle725's Avatar
Default cant shift
ok I have 2003 explorer 4.0 flexfuel I cant get it to come out of park . I took off the colom cover and found a little silver pin that if I push it down with a screwdriver I can shift gears. Is that the nuetral safety switch? and how do I change it. thanks
Old Jun 15, 2009 | 01:54 PM
oldtimer35's Avatar
This neutral safety switch is mounted on the tranmission. That could be the shift interlock pin, but that is not the problem. There is a shift interlock solenoid mounted on the column that pushes that pin, it is electrical. Check for voltage to it. If no voltage, then check your fuses, if you have voltage, the replace the solenoid.
Old Jun 16, 2009 | 07:27 AM
you just describied it thanks I did not know what to call it.
Old Jun 19, 2009 | 06:50 AM
wil the park interlock going bad take out your brake lights? I cant find a blown fuse but I have no brake lights
jimbokicksass
Feb 16, 2013 08:59 PM
homedepot
May 31, 2009 11:18 AM
blocker59
May 11, 2008 10:34 AM
justelmer
Jul 1, 2007 07:16 PM
