problems with truck running
Old Jun 13, 2009 | 03:50 PM
mustangmitch2010's Avatar
Default problems with truck running
i have a 1980 ford f150 ranger with a 351M. when i start it up it sometimes will idle sometimes it wont and then when i start to drive it i will get up to about 35 45 mph and then it starts to cut out and dies on me even when i give it gas......i have rebuilt the carb but on new spark plugs and spark plug wires, ignition coil, mechanical fuel pump, and a new rotor inside the distributor, and new distributor cap.....gimmie some ideas on how to fix it
Old Jun 15, 2009 | 01:09 PM
oldtimer35's Avatar
Is the egr valve opening up prematurely? Or is it already stuck open? You can tap on the base of the egr with the engine idling and see if the idle improves. You might have carbon stuck in the port on the valve.
Old Jun 19, 2009 | 06:33 PM
i figured it out i had a push rod that fell down into my engine on my third piston
Dawggtired
May 28, 2014 03:06 PM
iuecbrad
Nov 1, 2011 10:06 PM
wheelzzs
Jan 9, 2010 10:09 AM
babygirl111
Jun 27, 2008 07:15 AM
96F350Panel
Nov 27, 2007 02:59 PM
