Can not remove the oil drain plug?!
Old Jun 13, 2009 | 08:17 PM
peteryjg2008's Avatar
Default Can not remove the oil drain plug?!
It's the first time for me to change engine oil by myself. My car is 00 Taurus,DOHC. I found the oil drain plug underneath the engine in the center line of the vehicle. The 13mm socket fits the oil drain plug, but someone told me 15mm socket should be used. I am a little confused. What I found is not the oil drain plug? Unfortunately, there is no enough place to play the break bar, maybe my socket is too long, and then I can not remove the oil drain plug by open end wrench. It should not be seized because the engine oil was changed three months ago by a dealer. May I use penetrating oil? What should I do?
Thanks a lot
peter
Old Nov 10, 2009 | 01:43 PM
dmcomputerguy's Avatar
Unhappy Oil drain plug
Third time trying to reply
You need a mentor. Someone who will show you how to choose the correct tool for a task and to use it correctly.
There are too many things to pick up by reading.
MGood777
Oct 27, 2023 01:34 PM
crispyc21
Mar 13, 2013 09:08 PM
tony tiger 54
Apr 30, 2011 02:53 PM
Czecher01
Mar 7, 2007 10:08 PM
RNGMSTR
Feb 24, 2006 07:47 PM
