Ford CCRM's For Sale
Old Jun 15, 2009 | 03:42 PM
FordMan59's Avatar
Default Ford CCRM's For Sale
I have several CCRM's for sale for various Ford vehicles. I have them that will fit a '97 Escort and '96-97 Tauraus, '98-up Escort and some ZX-2's and may fit other vehicles. Send a PM with your part number and I'll see if I have a replacement. The CCRM's are $60. and your old CCRM. Since your car will not run without the CCRM I will charge a $15. core charge that will refunded when I receive the core. These parts cost $200-$300 if you buy them new from a Ford dealer. If your A/C isn't working there's a good chance this is your problem.
Old Aug 2, 2009 | 06:45 PM
FordMan59's Avatar
Bump.
Old Sep 21, 2009 | 07:16 PM
FordMan59's Avatar
Still available.
Old Sep 29, 2009 | 01:20 PM
jmartin6's Avatar
Question 98 Mustang GT CCRM
Do you have a CCRM for a modified 98 Mustang GT? My problem is that my radiator fan runs continually from the moment you turn the ignition key to the on position. Even at first start in the mornings. Would replacing this module solve this problem. Thanks, jmartin6
Old Sep 29, 2009 | 02:59 PM
FordMan59's Avatar
Default Mustang CCRM
I have some that came off of Mustangs, but I don't remember which ones they are. If you can get me the part number and send it to me in a private message I'll be glad to check to see whether I have it or not. I can't say for sure whether it is the CCRM or not, but it is possible that there's a bad relay causing the problem. I would suggest you get it diagnosed before buying a CCRM unless you just want to give it a try and if that isn't the problem have an extra. It's also possible that the coolant temperature sensor is bad causing the problem. Let me know if I can help you.
Old Mar 13, 2010 | 08:10 PM
FordMan59's Avatar
Bump.
Old May 29, 2010 | 09:42 AM
gilmanheather's Avatar
Default CCRM For 98 Ford Escort Zx2
Do you still have this part available? I need one and can't find anything used.
Old May 29, 2010 | 11:52 AM
FordMan59's Avatar
Email sent.
Old Apr 27, 2012 | 08:57 PM
Michael GingerKid Boone's Avatar
Hi i was wondering if you could help me find out what is wrong and were to locate it my fuel pump isnt getting any power to it i took it out and hooked it to an external battery and it still works im thinking its the Fuel Pump Relay but i can't find were it is located and i think i read somthing about the ccrm how i need to replace that and saw your prices i have a 99 Ford Escort zx2 i was wondering if you still have a ccrm available
Old May 23, 2012 | 01:59 AM
FordMan59's Avatar
I didn't notice your post until tonight, and know you've probably already found one. I'd need the part number from your old unit to let you know for sure. If you're still interested in one let me know.
farout_one
Jul 9, 2011 09:22 PM
FordMan59
May 4, 2009 10:06 PM
FordMan59
May 1, 2009 03:25 PM
Jennette_DeletedByREQUEST
Aug 8, 2006 11:28 PM
farout_one
Jul 9, 2005 10:07 AM
