oil leak from starter on Taurus?
Old Jun 17, 2009 | 10:20 PM
Bobt's Avatar
Default oil leak from starter on Taurus?
Oik appears to be leaking from starter where it is bolted to the housing. Is this a pan gasket or rear seal problem? 3.0l v6 12 valve
Old Jun 18, 2009 | 07:12 PM
way2old's Avatar
It could be the oil pan gasket, the rear main seal or a valve cover gasket. You need to determine where it is coming from. Clean it off really good and have some dye added to it. You can buy a utlaviolet detection unit fairly cheaply and it is easily spotted when the dye comes out.
jcasaccio
Oct 7, 2018 08:02 AM
mtnman42
Oct 19, 2012 07:08 AM
cutiepiereading
Nov 24, 2011 07:42 PM
jdm
Feb 26, 2006 08:38 PM
Tpr Jeff
Jan 8, 2006 05:06 PM
