2008 Escape Door Panel
Old Jun 19, 2009 | 12:41 PM
bluestage2's Avatar
Default 2008 Escape Door Panel
I was wondering if anyone knows how to remove the door panels on a 2008 escape.. One of the speakers is blown and sounds terrible but when I tried to get the door off it really didnt want to budge even after i took out 4-5 screws, and I know alot of people said to be careful because there are a ton of clips that break on them.
Any help would be appreciated! thanks
Old Jun 19, 2009 | 03:20 PM
Once you've removed the 5 screws, 1 on the lower leading edge of the trim panel, 2 on the trailing, 1 behind the the door handle finish trim, and 1 in the handle pull area.. Then you'll need to remove the forward 'sail panel' trim piece above the door trim panel.. Lift 'outward and up' to release the panel..
makuloco2000
Dec 13, 2014 08:41 AM
jugp
Aug 7, 2008 03:15 PM
chaud
Jul 22, 2006 01:55 AM
steveandbelinda
Jun 19, 2006 01:30 PM
