Tranny fluid type
Old Jun 22, 2009 | 02:44 PM
mjohnst123's Avatar
Default Tranny fluid type
I need to know the type of tran fluid that is used by my 1988 motor home that is a F350 cab and has a 460 engine. The front seal was leaking so the tran was dropped and a new torque converter put in and replacing the seal. Now need to fill with fluid and not quite sure the type. Don't have the owners manual for the vehicle. Thanks for any help
Old Jun 23, 2009 | 05:07 AM
You would need MERCON or MERCON-V Automatic Transmission Fluid or dual usage fluids
labeled MERCON/MERCON-V. MERCON Automatic Transmission Fluid is no longer be
manufactured as of July 1, 2007, therefore, availability of this fluid will only continue for however long it takes to deplete what remains in inventory.
shrek4472
Feb 13, 2011 09:38 PM
93f250xlt4x4
Apr 27, 2009 08:50 PM
FLJ
Mar 28, 2008 08:59 PM
87broncoll
Dec 18, 2006 08:02 AM
Shigg
Nov 22, 2005 02:19 AM
