Help with A/c
Old Jun 22, 2009 | 05:13 PM
fox1765's Avatar
Default Help with A/c
Have 97 CV P71 the ac compressor comes on and goes off, it acts like one would without the proper amount of gas in the system however a/c contractor put the gauges on and stated that it has plenty of R134A in it. bad relay?
Old May 12, 2013 | 07:46 AM
tempforce's Avatar
bad pressure sensor or a blockage in a line…
you need the gauges hooked up to watch pressures when the compressor tries to operate...
Old May 12, 2013 | 09:28 AM
The A/C systems as designed are supposed to cycle on & off. The timing of which is affected by things like ambient temp, engine RPM, cool setting to name a few.
If there is any moisture in the system it could be freezing at the orifice tube and causing the low press switch to open. It would be a good idea to do a little research on how the system is supposed to operate and some of the possible causes for what may or may not be a problem.
jd637
Feb 22, 2019 08:14 AM
jborushko
Dec 22, 2016 08:06 PM
