rearend
Old Jul 11, 2004 | 05:38 PM
bronco_willy's Avatar
Default rearend
can you take the guts out of 1995 rearend and put it in a 1987 rearend housing . the 1995 housing is bent.
Old Mar 3, 2005 | 02:30 PM
847alexc's Avatar
Default RE: rearend
That should not be a problem as long as the '87 model has the integrated RABS speed sensor in the pumpkin housing. At that point however, you will have practically rebuild rear end anyway, having to readjust the backlash and all of the torque specs and everything. it would probably be easier in the long run to simply buy new parts for the "87 housing, maybe reuse the carrier and axle shafts.
Good luck
gmm
Oct 28, 2015 04:04 PM
dreamcatcher
Aug 24, 2006 06:59 PM
yago
Sep 4, 2005 08:10 PM
bronco_willy
Nov 28, 2004 02:11 AM
mddscnstrctn
Sep 6, 2004 03:58 AM
