01 Ford Ranger pickup
Old Jun 24, 2009 | 08:37 AM
sky81's Avatar
Default 01 Ford Ranger pickup
I'm trying to help someone with a check engine light on in an 01 Ford Ranger pickup. It has the 4 liter single overhead cam V6.
The computer readout says that the oxygen sensor in "Bank 1, Sensor #2" has failed.
The problem is I don't know which cylinder bank is Bank 1, and I don't know what sensor Sensor 2 is.
How many oxygen sensors do these trucks have, anyway?
Thanks for the help.
Old Jun 24, 2009 | 06:43 PM
way2old's Avatar
Being a "V" engine, it will have either 3 or 4 sensors. Bank 1 is passenger side, sensor 2 is the one behind the converter. Before you replace the sensor, what was the exact code number? That will allow us to research the problem and offer more accurate advice as to the repair. A lot of people will want to replace the sensors if it has a lean code. So we really need the exact code number.
Old Jun 25, 2009 | 08:51 AM
sky81's Avatar
Here are all of the codes:
P0171 System Too Lean - Bank 1
P0174 System Too Lean - Bank 2
P0300 Random/Multiple Cylinder Misfire Detected
P0136 O2 Sensor Circuit Malfunction Bank 1 Sensor 2
P1131 Manufacturer Control Fuel Air Metering
P1151 Manufacturer Control Fuel Air Metering
mpearce69
Apr 22, 2011 11:58 AM
jw4477
Apr 15, 2008 01:30 PM
ghosttownguy
Aug 18, 2007 02:14 AM
