headlight switch
Old Jun 25, 2009 | 08:14 PM
vv2020's Avatar
Default headlight switch
I need to know how to remove the pull **** on a 1996 Bronco headlight switch. I can see the nut that needs to be removed, but I'm not sure if I need to remove the plastic shroud that houses this or what. I am replacing it with a new one. thank you
Old Jun 26, 2009 | 03:21 PM
Look at the area where the shaft enters the ****.. You'll see a squared 'notched' or cutout area at the base of the ****.. Use a hook shaped tool and using a pullling force, pull with some light tension on the retaining clip and pull the **** off the shaft.. You can also reach under the dash and up high onto the H/L switch.. There on the headlight switch body is a release button that you 'hold in' and pull the complete ****/shaft assembly from the switch..
ecm331@aol.com
Oct 27, 2012 06:24 PM
jrskydawg68
Dec 27, 2007 06:41 PM
flygirl007
Jul 29, 2007 03:13 PM
daddio360
Jun 13, 2006 07:37 PM
a1parrothead
Nov 21, 2004 02:52 AM
