1999 Ecort runs rough mechanics don't know why
Old Jul 3, 2009 | 04:26 PM
picabia's Avatar
Default 1999 Ecort runs rough mechanics don't know why
I've had my 1999 Escort in the shop 3 times for the same issue -- runs rough, check engine line periodically comes on. Mechanics have done all the things that needed doing - replaced spark plug wires (which needed to be done anyway) cleaned fuel system. There're no vacuum leaks and the plugs aren't fouled. The computer did not register an error code, or if it did, it cleared by the time the mechanics looked at the car.
If you've had this problem and resolved it, what did you do?
Old Jul 6, 2009 | 03:52 PM
FordMan59's Avatar
Do a compression test to make sure the compression is up on all the cylinder. These engines have a track record or dropping valve seats. Hopefully that isn't your problem, but better to find it now if it is than to wait until it drops completely out and does more damage.
Old Jul 9, 2009 | 10:17 PM
picabia's Avatar
FordMan59,
Thanks very much for your response. I'll look into it.
Regards,
Picabia
Screenwriter
Dec 8, 2016 08:37 PM
tshelto2
Mar 3, 2013 02:16 PM
joshuathomason
Dec 15, 2009 07:24 AM
louchris
Nov 29, 2007 11:58 AM
