2005 Excursion A/C Problem
Old Jul 8, 2009 | 11:46 PM
tatman's Avatar
Default 2005 Excursion A/C Problem
Here recently, me digital climate control will randomly black out. When it does this I have no A/C. Also, when it is working, it seems as though it's not quite blowing as cold as it should be. I checked for leaks and coolant levels, and these appear fine. Help! it's too hot to be dealing with this. Thanks
Old Jul 23, 2009 | 05:45 AM
You may need to replace the electronic climate control unit. Since it's blanking out, it also may not be registering the proper temperature setting(s). You may have it set down to 60, but the unit may on ly be registering 68 nad such.
bartlc
Dec 3, 2011 07:57 PM
rbknisley
Jun 23, 2011 12:40 AM
penz
Oct 30, 2009 12:30 PM
larmak90
Oct 22, 2007 09:46 AM
larmak90
