Which model is my E-Series?
Old Jul 19, 2009 | 03:53 PM
pleasuremann's Avatar
Default Which model is my E-Series?
I have an 86 ford econoline automatic. Just wondering how to tell if it's a 150, 250, or 350.
Also, there seems to be a transmission fluid leak. I've heard great things about Justice Brothers transmission stop-leak.
I'm thinking of installing a new fuel filter; the van has almost 100k miles on it and it's certainly been long enough since it has been changed. I'd appreciate any links or information about how I'd install a new one.
Lastly, I'll need to change my oil. Any tips on oil changes for this model would also be greatly appreciated.
Old Jul 22, 2009 | 07:23 AM
What's the VIN number? Fuel filter will either be an IN-LINE or a canister filter. You may even have both. Both would be located along the inner frame rail under the driver's side. The cannister filter will ber located inside of a black housing (sometimes behind a steel plate). Just follow the fuel lines from the tank and go forward. As far as oil goes, just use a good quality 10W-30 motor oil and filter. Don't forget the air filter. How are the plugs and wires? Ignition coils are pretty cheap also. Due to age, a good set of plugs, wires and coil always makes for a smooth runner.
Old Jul 26, 2009 | 09:09 PM
Hey, thanks common sense for the reply. The VIN is 1FDEE14N9GHB02617. The E1 is an indicator of an E150, correct?
I followed my fuel lines and found what looks to be a canister just where you said it would be. If I had both like you suggested, where would my IN-LINE filter be and what would it look like?
Good idea to order a new fuel filter/air filter from a shop like KNECHT'S?
Thanks for your help.
Old Jul 31, 2009 | 04:02 AM
If you have an In-Line filter, crawl under the driver's side and it should be on the driver's side frame rail right under the drivers seat. It will be a metal filter about the size of a soda can with single Inlet/Outlet lines connected to it.
Your VIN number: 1FDEE14N9GHB02617
World Manufacturer Identifier - 1st, 2nd, 3rd Positions:
Manufacturer: Ford Motor Company, USA
Make: Ford
Vehicle Type: Incomplete Vehicle (Cargo)
Brake Type and GVWR Class - 4th Position:
Brake System: • Hydraulic brake system, Class E, GVWR 6,001-7,000 pounds
Line Series, Chassis Type, Body Type - 5th, 6th, 7th Positions:
Line Series: Econoline - E150
Chassis Type: 4x2
Body Type: Cargo Van - Regular Van
Engine Type - 8th Position:
Engine: 5.0(302cid)
Cylinders: V-8
Fuel Type: Gasoline
Horse Power: 185
Model Year - 10th Position:
Model Year: 1986
Assembly Plant - 11th Position:
Assembly Plant: Lorain: Lorain, Ohio
Production Sequence Number - 12th - 17th:
Sequence Number: B02617
TylerDoucet
May 24, 2011 03:26 PM
STUFFSK825
Sep 6, 2007 06:26 PM
crs5357
Oct 20, 2005 09:45 PM
crs5357
Jun 16, 2005 11:21 AM
Ralph the Wrench
Apr 15, 2004 05:35 AM
