2002 Ford excursion door ajar light on
Old Jul 21, 2009 | 06:18 PM
supportfop's Avatar
Default 2002 Ford excursion door ajar light on
I cant figure out why the door ajar light in on as well as the dome light and floor board lights. All the doors are closed and tight. I can't find out where the sensors are located to see which door is the problem.
Old Jul 23, 2009 | 05:50 AM
Spray all of the door latches with silicone spray. The light switches are built into the latches. These will tend to hang up causing the issue.
mike 96 ws6
Sep 25, 2012 08:25 AM
mholder
Oct 3, 2011 06:03 PM
oceanblue_2001
Feb 27, 2010 05:16 PM
Zapman
Feb 16, 2009 06:29 PM
Mike11C
May 27, 2007 02:14 PM
