01 f150 4x4 front end squeek
Old Jul 22, 2009 | 08:17 PM
bmarnall's Avatar
Default 01 f150 4x4 front end squeek
Just started to have horrible squeeking from the front end. notice this mostly while going slow, turning and over bumps. Frt end seems to be tight and there is no steering, wandering, or tire wear issues. new ball joints last year, new shocks this year. I've heard sway bar bushing can cause squeeking but cant believe it would cause this much noise. Any ideas. truck has 150,000 miles on it.
Old Jul 23, 2009 | 08:05 AM
Bullitt94's Avatar
Lay under the truck and have a friend bounce it a bit to see where the noise is coming from. Usually a squeak is caused from a need for grease, or from a part that can't be greased...
Old Jul 23, 2009 | 02:24 PM
barnall's Avatar
tried that, cant get it to squeek enough while stationary, but if slowly rolling over bumps it squeeks like crazy.
Old Jul 24, 2009 | 05:26 AM
It's either a upper or lower ball joint(s). This is a common problem as they are greaseless. These use a steel ball stud in a nylon socket. Is very noticable when rolling slow and turning the tires or going over bumps slow like into or out of a parking lot and such.
Old Jul 24, 2009 | 06:38 AM
bmarnall's Avatar
ball joijnts are only 2 years old and are aftermarket ones with grease fittings. The top balljoint came as a complete arm assembly with bushing so I think I can rule that out.
Old Jul 24, 2009 | 11:26 AM
2 years old doen't mean that one or the other couldn't still be bad. I would then try spraying the swaybar bushings and any other bushing you can find with silicone spray to see if it goes way.
Old Jul 27, 2009 | 08:37 AM
Bullitt94's Avatar
Agreed.
Also, have the ball joints that were put in been greased in the past two years?
Old Aug 15, 2009 | 07:10 AM
REORACING's Avatar
check the steering idler arm
dang482001
Apr 26, 2007 12:05 PM
93f250xlt4x4
Dec 16, 2006 10:42 PM
93f250xlt4x4
Sep 8, 2006 12:08 AM
93f250xlt4x4
Sep 3, 2006 09:56 PM
littlefili1
May 11, 2005 04:49 AM
