Ignition/Distributor Problem on a 1984 460
Old Jul 25, 2009 | 02:39 PM
tbucketflyer's Avatar
Default Ignition/Distributor Problem on a 1984 460
I have been having intermittent starting problems with my 460 powered RV so I replaced everything, the rotor, cap, wires and plugs. Then it would not start at all. I noticed one of the 3 wires (the yellow one) coming from the distributor had the insulation dried and broken off and the wire was grounding out.
I have a constant negative feed to the coil which gives me a very week and constant spark to the plugs and as I said, it will not start.
Could this yellow wire grounding cause something to malfunction and is this the cause of the constant negative feed?
Old Jul 30, 2009 | 06:53 PM
denthead1's Avatar
There should be no wires grounding out ever. There sometimes is a grounding wire going from the hood of a car to the back fire wall but this is needed to complete the circuit for the overhead light on the hood.
drybasement
Oct 19, 2013 09:00 PM
mund
Jun 13, 2011 04:41 PM
dbonnell
Jul 8, 2007 07:55 AM
wetracer
Feb 15, 2007 11:37 PM
wetracer
Feb 15, 2007 02:10 PM
