lift Kit
Old Jul 27, 2009 | 03:43 PM
countryboyf150's Avatar
Question lift Kit
I own a 1999 ford f150 lariat 4x4 offroad, it has 127,000 miles on it. i want to put a 3" Performance Accessories body lift on it($213).
What are the Pros and Cons of doing this, Should i put a 2" body lift, will it mess up my truck, Help me please ????
Old Jul 28, 2009 | 04:33 PM
Bullitt94's Avatar
Pros are you get more lift and ground clearance which gives better articulation in offroad situations.
Cons may be in trying to sell the truck. Not everyone wants a lift, but then again some do.
A lift shouldn't harm your truck.
Depending on what you plan to do with the truck with a lift will help determine how much you may need.
Old Jul 28, 2009 | 11:20 PM
Disowned's Avatar
What's the reason for the lift, I would think it's to clear larger tires but if it's just to lift the truck and not slap some larger tires on I wouldn't go 3 inches I would go 1.5 - 2. reason being that I find that the trucks that do the 3 inch body lift and not put bigger tires on looks a little odd.
Pros... great if you wand to clear larger tires without rubbing fenders and rear quarters.
Cons... You have to make sure the e-brake cables are long enough, as well as the stearing linkage and so on.
Just my 2 cent's but I have lifted trucks and went down that route before.
Jville808
Oct 21, 2006 10:44 PM
mustangsidewinder
Jan 23, 2006 03:37 PM
Trader4Less
Oct 19, 2005 05:17 AM
jamesguck
Jun 20, 2005 05:27 PM
FordStype
May 17, 2005 09:28 PM
