where to get these minor parts for a 1981 ford f100 custom
Old Jul 30, 2009 | 06:03 AM
nicolelapan's Avatar
Smile where to get these minor parts for a 1981 ford f100 custom
i need to know if the following issues are fixable for a 1981 ford f100 custom. it's an automatic straight six 4.9L
how much would a steering column changeout cost? i was just going to buy the spring/wire that connects from the column to the PND21 because the ticker is stuck at P.
my signal also won't stay down or up when i use it. advice on how to fix it?
where can i get a dash cap? dashboard's kinda messed up and i don't want to replace the whole thing. i heard about caps that fit snug right over it? any ideas?
any advice would be insanely appreciated. thanks.
Old Feb 2, 2010 | 10:10 AM
mojo83's Avatar
I am not sure of the cost of a colomn but i do know that you can sometimes get the connections for the shifter in a junk yard fairly cheap along with the clips for your signal lights. However if you are having a hard time finding one in a junk yeard as i know i have in the past with mine you can always look at LMC truck they are expensive on somethings but as a last option its something to look into they will probably have a dash as well for you. Also sometimes napa carries a few after market parts that will work for you I know I bought a few window cranks from them and a few clips.
Old Feb 6, 2010 | 06:26 AM
ralphie250's Avatar
if you call the dealer and they tell you it is obsolete they can call somewhere and find them i dont remember what the place is called. it has happened to me
Vladtepest
Nov 12, 2007 05:55 PM
whoyourdaddy49
Feb 11, 2007 07:45 PM
davidsca
Jun 11, 2006 09:21 PM
sethro
Jul 21, 2005 10:25 PM
