Ford f150 Check engine light
Old Aug 9, 2009 | 03:35 PM
daltonbird's Avatar
Default Ford f150 Check engine light
Ok so...Will a severly dented tail pipe on a ford f150 supercrew cause a check engine light to come on? I have taken mine to 5 different shops and no one can figure out why the lights on.. I just noticed the tail pipe was bent the other day. I have no clue what to do now. Its a 2004 and the only reason it will not pass smog is the stupid light. PLEASE HELP ME
Old Aug 9, 2009 | 04:42 PM
way2old's Avatar
What is the code that is causing the light to come on? Need exact number.
Old Aug 9, 2009 | 05:41 PM
green_monsta's Avatar
Maybe there's a crack or leak of some sort just before the cat. How did the pipe bend?
Old Aug 9, 2009 | 06:41 PM
daltonbird's Avatar
The pipe bent from the back to the passenger side of the truck pinching the pipe making it a 90 degree angle. But wouldnt the people at the smog shop stick something in the pipe itself? Correction ( the pipe is more bent to the front end close to the tire.
Old Aug 9, 2009 | 06:47 PM
daltonbird's Avatar
-- Has CODE PO175-RICH BANK2.
sky81
Jan 27, 2013 11:27 AM
Jared94Ford
Aug 19, 2009 07:55 PM
kaidi
Jan 11, 2009 01:24 AM
allensimpson
Jan 10, 2008 09:40 PM
Jason11
Jan 10, 2008 01:25 PM
