A/C Freezing up
Old Aug 10, 2009 | 11:14 AM
hfb1957's Avatar
Default A/C Freezing up
I have a 2007 Taurus and for a few weeks now if I run the air on max and the fan on low the fan stops blowing air through the vents. If I turn the fan to high it sounds like there is blockage in the flow path. I guess it is freezing up. If there is anyone that can help me please let me know what to do. I had the condensor replaced in February but it just started freezing up in the last month or so. Thanks in advance for your help. Henry
Old Aug 10, 2009 | 07:51 PM
way2old's Avatar
Check the low pressure cut out switch. If it does not turn off the compressor, the evaperator will freeze up and air flow is blocked.
Old Aug 11, 2009 | 06:10 AM
You may have a bad evaporator temperature monitoring thermostat. The thermostat monitors the temperature of the evaporator fins and controls system operation within set limits. The thermostat usually cycles the system between a minimum of 2°C [or 35.6°F] and a maximum of 8°C [or 46.4°F] to maintain the evaporator at the required temperature. If this thermostat is bad, the evaporator will ice up causing the lack of air flow.
Old Aug 17, 2009 | 11:02 AM
hfb1957's Avatar
Default Low pressure cut out switch
I cannot find a low pressure cut out switch for this car. Could it be called something else. Also does removing this switch cause the freon to be released or is it a sealed system. The only switches listed for this car arethe a/c clutch cycling switch. If this is it I can probably get it installed myself as long as all the freon won't escape.
Old Aug 17, 2009 | 06:38 PM
way2old's Avatar
That is the same part. You can change the part yourself. It just screws off. There may be a miniscule amount of refrigerant escape, but it is nothing to worry about.
fredreddy16
Aug 19, 2009 05:42 AM
fd25t6
Dec 11, 2007 04:14 PM
