Fouling sparkplugs
Old Aug 14, 2009 | 11:52 PM
REORACING's Avatar
Default Fouling sparkplugs
1997 F-150, 4.6L V8, keep fouling #3, #4, not oil, CHECK ENGINE LIGHT, code PO156, 02 sensor circuit malfunction (bank 2 sensor2), have replaced down stream 02 sensor and cats. NEED HELP PLEASE!!!!
Old Aug 15, 2009 | 03:00 PM
way2old's Avatar
Have you checked to see if the injectors are leaking?
Old Aug 16, 2009 | 07:29 AM
REORACING's Avatar
yes, no injector leak
Old Aug 16, 2009 | 12:25 PM
way2old's Avatar
Are the wires good? What have you done besides replacing the O2 sensor? Please give us some history on the vehicle.
Old Aug 17, 2009 | 05:55 AM
Here are some common causes for a P0156 code.
1. Pinched, shorted, and corroded wiring and pins
2. Crossed sensor wires
3. Exhaust leaks
4. Contaminated or damaged sensor
5. Bad PCM
Also, how did you check your injectors to see if they were leaking or not?
AjzPop
Jan 20, 2012 07:37 PM
beaners
Mar 23, 2010 06:45 AM
jonrock
Oct 6, 2007 06:07 PM
coater
Nov 25, 2005 05:01 AM
coater
Nov 21, 2005 02:26 AM
