rough acceleration
Old Aug 29, 2009 | 04:53 PM
typhoon55's Avatar
Default rough acceleration
recently getting a misfire at 4000 rpm acceleration
after OBDii reading I got P0113
I earsed the code and they did not return but still same symptom
I am now thinking a bad cop
2000 duratec
Old Aug 29, 2009 | 09:12 PM
way2old's Avatar
If it is while you are moving, check fuel pressures first. A plugged filter will cause a high speed miss. Then you can check the ignition system. If you are in park and doing it, that is normal for the computer to shut off the fuel.
Jmart045
Mar 13, 2014 09:17 PM
qwikrnu
Dec 3, 2012 02:45 PM
Ross
Sep 13, 2011 09:44 PM
94lonerangergurl
Mar 3, 2008 01:03 PM
bmerlino
Nov 16, 2007 08:39 AM
