piston info?
Old Sep 23, 2009 | 03:02 AM
sctrep's Avatar
Default piston info?
ok so i have a 302 .40 over and it has these pistons. anyone tell what they may be from this pic.
thnx
Old Oct 10, 2009 | 01:59 PM
oldskooloutlaw's Avatar
They are aftermarket pistons with valve reliefs for large intake valves probably with a high lift cam.IMHO
Old Oct 13, 2009 | 12:04 AM
sctrep's Avatar
thnx. also i have these lifters. any idea what kind they may be. and is there a way to measure lift by how much of the lifter is above the lifter bore. i mean is there a standard hight so i can compare.
the one on the right is OEM the left is aftermarket. it says L900
Old Oct 13, 2009 | 10:52 AM
Default RE: camshaft lift
No those are regular flat tappet hydraulic lifters,in order to obtain cam lift/duration you will need to id the cam model and make,then you can get the spec sheet,it more than likely be a ford cam and have a letter stamped on the front where the cam gear mounts.
tinman02
Jan 28, 2010 09:19 AM
WJBishop
Sep 2, 2009 04:51 PM
RedMule
Dec 15, 2007 03:04 PM
tccriv
Jun 26, 2007 03:59 PM
DanP
Apr 13, 2007 11:47 AM
