2001 Ranger XLT Turn signal issue
Old Sep 28, 2009 | 01:35 AM
Zadias's Avatar
Default 2001 Ranger XLT Turn signal issue
Right Rear turn signal is out. Though the Turn signal and the Brake light are the same bulb and the Brake light does work.
Front right signal is working fine though i Am getting the fast blink on the signal there and on the dash.
No idea what i need to replace. Any help would be .. helpful
Old Oct 13, 2009 | 09:17 AM
stuart40ca's Avatar
Not sure if you repaired this by now but in case you haven't.
Replace the rear bulb.
The filament has probably fallen down and causing the affect.
You can try that bulb in the working side to rule it out.
If the bulb is good then look at the wiring from the switch back.
Glowbug
Jan 28, 2022 12:43 PM
Tslayer
Apr 3, 2015 08:21 AM
Catch and Eat
Jun 6, 2012 10:14 AM
shwoke
Jan 30, 2011 06:42 PM
skinsgamer
Sep 21, 2007 02:37 PM
