98 f150 303 code
Old Sep 28, 2009 | 06:34 PM
gspaniel's Avatar
Angry 98 f150 303 code
My 98 f150 has a miss on cylinder 3 [ code 303 ] i have changed wires , plugs ,coilpack , and the injector with no results . Does anybody have an idea what it could be ? The compresion is good on all cylinders .PLEASE HELP
Old Sep 29, 2009 | 06:27 AM
way2old's Avatar
Do you have the correct information posted?? Or just a typo?? P0303 is cylinder number 3 misfire.
Old Sep 29, 2009 | 04:39 PM
gspaniel's Avatar
sorry you are right its cylender 3 . Dont know what I was thinking
Old Sep 29, 2009 | 06:22 PM
way2old's Avatar
What size engine? The V8 is known for losing a cam follower causing a misfire. Is it still missing or is it just the code coming back? What is the compression readings on all cylinders? Sorry for the questions.
Old Oct 16, 2009 | 08:52 PM
romeodz's Avatar
If its the V6, verify you are not also loosing engine coolant. My 1997 and a misfire code along with coolant loss and I had to replace the lower intake manifold gaskets. Basically a 4 to 5 hour job.
Old Oct 22, 2009 | 12:17 PM
gspaniel's Avatar
v6 4.2 lower manifold gasket leaking coolant into cylinder1and3 found it when i checked compression Thanks for the help
Old Oct 22, 2009 | 06:38 PM
way2old's Avatar
Thanks for the fixed post. We do not get that enough.
Old Oct 24, 2009 | 03:32 PM
romeodz's Avatar
No problem.. This site is where someone told me what was wrong with my engine. Glad to hear your running again.
romeodz
maineman
Aug 11, 2018 08:23 PM
cwildkats
Dec 27, 2012 09:59 AM
Crimepuppy
Aug 23, 2009 05:24 AM
dwpkjp23
Feb 26, 2008 08:50 PM
dlear
Feb 19, 2006 08:46 PM
