Go Back   Ford Forum - Enthusiast Forums for Ford Owners > Ford Cars > Ford Five Hundred
Welcome to Ford Forum!
Welcome to Ford Forum,
Old 10-06-2009, 08:29 PM
harleyvette harleyvette is offline
Default Front end noise
I have a 2005 fivehundred SEL fwd with all kinds of front end noise. makes noise when hitting bumps as well as when turning wheel at low speeds. any ideas?
Old 10-07-2009, 12:39 PM
Use Common Sense Use Common Sense is offline
If it's a clunking noise, it's probably worn sway-bar end-links. Easy to replace, just two nuts. Do all of them as they're not very costly.
__________________
2004 Freestar Limited 4.2 V6 w/Water Injection & Iridium plugs
2008 Mercury Sable 3.5 V6 w/Opened Air Box
AMSOIL Lubricants and Filters in everything
"Have a good day, and a better one tomorrow"
Old 11-01-2009, 05:48 PM
fsimon fsimon is offline
Default 06 Five Hundred AWD
My driver front has like a rattling noise when I hit bumps. Would that be the sway bar as well. I wondering strut or front end bushings.
Old 11-02-2009, 07:08 AM
Being an 06, I would still suspect sway bar end links. These can cause CLUNKING over small bumps to a RATTLING noise. Sense the end links are plastic with a metal ball stem in a plastic socket, these wear very easily. You can check them by putting the car up on ramps. This will keep the end links in their normal position. Then get under the vehicle and wiggle/move the end links around to see of any of the ball/sockets are loose. I have the original ones on my Freestar with almost 75,000 miles on them. However, I use a greese needle on my grease gun and fill the boots up with grease every spring and fall. I also do my ball joint boots the same way. Hope this helps.
__________________
Old 11-04-2009, 07:45 PM
Thanks. Out of curiosity, when removing the sway bar, can the car be jacked and sway bar removed while wheel is sagging or does it need hub up in normal position?
Old 11-05-2009, 06:29 AM
Easy as pie to replace. Jack up one side of the vehicle and place a jack stand under it. Remove the tire. The end sway bar end link is right there. Remove the upper and lower nuts (a metric box/socket and open end wrenches needed) and pop the link right out. Install the new link, tire and let it down. Repeat on other side. Don't forget to have a cup of coffee in between. Can't work without a coffee break.
__________________
Tags
09, 2004, bar, end, excursion, f250, focus, ford, freestar, front, hundred, makes, noise, sway, taurus
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
