Go Back   Ford Forum - Enthusiast Forums for Ford Owners > Ford Trucks, Ford Vans & Ford SUV's > Ford F-150
Welcome to Ford Forum!
Welcome to Ford Forum,
Old 10-12-2009, 09:01 PM
91F150XL 91F150XL is offline
Default Rough idle/arcing at plug
I have a 91 F150 with the 300. I've been having trouble with the truck idling rough and shutting off when I hit the clutch to come to a stop. I started it tonight and checked for arcing and I can see at least 3 of the wires arcing where they meet the plug. Would that be a bad plug or wire? Possibly a coil causing problems? Cap and rotor were replaced approx. 6 months ago and so were plugs.
Old 10-13-2009, 08:55 AM
Bullitt94's Avatar
Bullitt94 Bullitt94 is offline
1970 Ford Bronco
If there is arcing, chances are the wires are shot. Plug wires need to be replaced or put on all the way if there is arcing.
__________________
1994 Ford Mustang GT
1990 Ford Bronco II
2001 Lincoln LS V8
1970 Ford Bronco
2006 Harley-Davidson Sportster Custom
If you don't already own a Ford (or Ford owned product), get one.
Old 10-13-2009, 07:52 PM
Default bump
I'm gonna bump this up, I replaced the wires, coil, and plugs and still have the same missing, arcing and low idle. Again, cap and rotor were replaced this past march. I'm not sure as to what else it would be.
Old 10-20-2009, 10:22 AM
nickt892003 nickt892003 is offline
the only thing i can think of is you may have a short somewhere causing the wires to prematurely arch....good luck
Old 10-20-2009, 04:12 PM
Bullitt94's Avatar
1970 Ford Bronco
Make sure the wires aren't touching anything en route to the plugs that could cause the wires to fail and ground out (i.e. exhaust manifold).
Also, when it's dark out you can opend the hood and watch for the spark to see where it is happening.
__________________
1990 Ford Bronco II
2001 Lincoln LS V8
1970 Ford Bronco
Old 10-21-2009, 09:16 PM
Yeah, that's how i found out it's arcing at the plug. I'm just gonna have to start tracing wires and try to find a short. I know it's not touching the manifold or anything seeing as it's a 6 cylinder.
Old 10-21-2009, 09:40 PM
Bullitt94's Avatar
1970 Ford Bronco
If it's arching at the plug, then your plug wire probably isn't on all the way. If it has like that for a while, then the wire is probably fried from the arch and will need to be replaced.
__________________
1990 Ford Bronco II
2001 Lincoln LS V8
1970 Ford Bronco
Old 10-22-2009, 04:17 AM
Use Common Sense Use Common Sense is offline
Did you put dielectrical grease on the plug end and inside the wire boot(s)? This will help eliminate spark leakeage at the plug. And like Bullitt94 stated, ensure that the plug wire is seated and locked onto the plug.
__________________
2004 Freestar Limited 4.2 V6 w/Water Injection & Iridium plugs
2008 Mercury Sable 3.5 V6 w/Opened Air Box (Just traded in 8/19/10)
2010 Lincoln MKZ AWD (Just took delivery 8/19/2010)
AMSOIL Lubricants and Filters in everything
"Have a good day, and a better one tomorrow"
Old 10-22-2009, 07:32 PM
Yeah, I greased the caps and made sure the wires are seated all the way. The only thing I can think of now is like NickT said, a short or bad ground. Are there any other grounds on the 6 cylinder besides the one running from the intake manifold to the firewall? I haven't got a chance to check yet if there is one from the block to the frame or not.
Old 10-23-2009, 09:00 AM
Bullitt94's Avatar
1970 Ford Bronco
I am under the impression that you saw the arching and it was at or near one of the spark plugs. Is that correct? If you can/have seen the spark jump, that is where the problem is.
__________________
1990 Ford Bronco II
2001 Lincoln LS V8
1970 Ford Bronco
Tags
04, 94, arching, arcing, coil, f150, ford, gt, idle, mustang, plugs, ranger, replaced, rough, spark, stopping, wires
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Featured Sponsors
Ford Accessories
- Ford Exhaust
- Catalytic Converter
- Air Bag Suspension
- Leather Seat Covers
- Flowmaster Exhaust
- Truck Accessories
New Sponsors
© Internet Brands, Inc.
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
