Go Back   Ford Forum - Enthusiast Forums for Ford Owners > Past Ford Models > Windstar/Aerostar
Welcome to Ford Forum!
Welcome to Ford Forum,
Old 10-14-2009, 11:41 PM
sharphome sharphome is offline
Default 2000 Windstar sqwualling noise with belt off!
My windstar is making a bad squalling noise. I thought it was the idler pulley so I replaced it. Still did it. Replaced the water pump, still did it and getting worse. I took the serpentine belt off and ran it and it still has that terrible squalling noise and sometimes it about kills the engine. Any suggestions of what could do this with the belt off? I thought it could be a timing belt pulley but found out it has a timing chain!! HELP!!!!
Old 10-15-2009, 12:21 AM
Hayapower Hayapower is online now
Welcome to the site..
On the front of the engine you'll see a 'short' looking distributor assy. with a wired sensor on top.. That is the camshaft synchronizer with the CMP (cam position sensor) attached topside.. The shaft inside as well as the housing will run dry from lack of lube and make a terrible chirping/squealing noise.. Place a long extension (or a stethoscope if you have one) extra long screwdriver, round rod ect. and place one end at the base of the synchronizer and the other end against your ear.. If the synchronizer has run dry it will be 'very noticable' with a listening device..
Here's a generic image of what the synchronizer looks like...
__________________
05 F250 C/C FX4 6.0
1969 Firebird Trans Am
2003 Hayabusa GSXR1300
Old 10-15-2009, 08:34 PM
Thanks, it sure sounds like that is where it is coming from. I hope so, that looks like one of the easier fixes.
Old 10-15-2009, 08:35 PM
thanks, that is sure what it sounds like. i hope so, it would be one of the easier fixes it looks like.
Old 10-15-2009, 10:24 PM
The synchronizer is timed/position sensitive..
If you can accurately 'scribe mark' the base of the synchronizer housing (preferably before removing the hold down) and the block area marked where the housing enters,, and then again scribe the upper housing with an alignment mark, making note or an accurate indication of the upper shaft 'pointing postion' you can usually change it out without any trouble..
__________________
05 F250 C/C FX4 6.0
Tags
2000, 2003, 2004, 30, belt, camshaft, chain, ford, freestar, noise, probe, squeal, synchronizer, timing, windstar
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
