1985 4.9 300 6 idles erraticlly
Old Oct 15, 2009 | 07:47 PM
jpoore_82's Avatar
Exclamation 1985 4.9 300 6 idles erraticlly
I have a ford 1985 ford f-150 explorer pick up that I just got done converting into a 4wd 4speed. Now when I start the truck it idles so high that it sounds like it is going to blow up. The only time it slows down and sounds anywhere near normal is when I let the clutch almost all the way out, Or if I let the engine run and push the butterfly alittle more closed. But then the engine shakes real bad. I had the carb rebuilt but not sure if it was done right. New manifold gasket,plugs,wires,egr gasket, you name it Ive checked or changed it. Or have I? Could really use some help from someone who knows for once. thank you
Old Oct 15, 2009 | 09:37 PM
Bullitt94's Avatar
It's possible the idle adjustment scres got turned in too far when the carb was rebuilt. Try backing the screw out (located neat where throttle cable connects to carb) to see if you can slow the idle.
87Mojo
Jun 4, 2019 05:41 PM
jpoore_82
Oct 15, 2009 07:20 PM
mike1980
Feb 13, 2006 05:28 PM
ogre89
Aug 7, 2005 10:41 PM
civshocker
May 26, 2005 12:02 PM
