my 02 Zx2
Old Oct 15, 2009 | 08:17 PM
kevinsgtp's Avatar
Default my 02 Zx2
ok so my 2002 zx2 speedo and odometter have been cutting out. they would work sometime then not others. now they just dont work at all. i relplace the VSS and didnt fix it. so i think its a bad ground becasue the horn is also not working. but when the speedo works the horn works. now i know they have the same ground wire but i dont know where the ground is and i cant seem to find it anywhere on the net. can someone please help me.
thanks kevin
Old Oct 15, 2009 | 10:39 PM
Welcome to the site Kevin..
Coupe? Sedan?
Main ground should be near the starter. Looks to be a couple of other connectors in line that carry the ground, and a group splice but doubt the splice would be the cause.. If it were out at the starter, think there would be more issues other than the speedo and horn involved.. Sedan appears to have a joint connector that contains the ground for the cluster out on the left fender apron behind the Constant Control Relay Module, but being a joint connector would affect multiple components like fuel pump, cooling fan ect..
Old Oct 19, 2009 | 03:18 AM
kevinsgtp's Avatar
well the cooling fan fuse blew
JoeSixPack
May 10, 2018 12:34 PM
farout_one
Jul 9, 2011 09:22 PM
Ritehsedad
May 14, 2005 11:28 AM
badboy zx2
Apr 8, 2005 11:38 PM
FordZX2
Sep 4, 2004 10:30 PM
