Go Back   Ford Forum - Enthusiast Forums for Ford Owners > Ford Trucks, Ford Vans & Ford SUV's > Ford F-150
Welcome to Ford Forum!
Welcome to Ford Forum,
  #11
Old 10-20-2009, 08:28 PM
Bullitt94 Bullitt94 is offline
1970 Ford Bronco
Did you do the check of the intake gaskets?
__________________
1994 Ford Mustang GT
1990 Ford F-150
2001 Lincoln LS V8
1970 Ford Bronco
2006 Harley-Davidson Sportster Custom
1990 Ford Bronco II
If you don't already own a Ford (or Ford owned product), get one.
  #12
Old 10-22-2009, 08:49 AM
nickt892003 nickt892003 is offline
check your spark and make sure its hot enough....also i would check the tps (throttle positioning sensor) sometimes those can make weird things happen
  #13
Old 10-22-2009, 07:36 PM
way2old way2old is offline
The overdrive light and the code for the EPC may be related. The EPC solenoid can be changed by just removing the pan. Your problem may lie in the transmission. You may need to have it checked out at a transmission shop.
__________________
People are like Slinkies. Not much use, but it still makes me smile whenever I see one tumble down the stairs.
http://i153.photobucket.com/albums/s.../youtheman.gif
  #14
Old 10-22-2009, 07:53 PM
if it is the tranny soleniod its not that hard to do...you just drain the tranny fluid and remover the pan (buy a filter and gasket set when you do this) and the soleniod is held up by to bolts and a couple wires and you drop it and snip the wires re butt connect them to the new one and put it all back together its that simple but the tranny soleniod shouldnt have anything to do with how it runs just how it shifts
  #15
Old 10-23-2009, 10:03 AM
1970 Ford Bronco
Can you feel it shutter when reving the engine in neutral, or does it only do it when in gear? If it only does it in gear, you probably have tranny issues (as otherss mentioned above).
__________________
1990 Ford F-150
2001 Lincoln LS V8
1970 Ford Bronco
1990 Ford Bronco II
  #16
Old 10-23-2009, 08:55 PM
jody jody is offline
Have you checked your coils. Mine did the same thing and i had a bad coil.
Tags
2001, die, engine, escape, f150, f350, fine, ford, gas, idles, press, problems, schrader, shuttering, shutters, transmission, truck, valve
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
