2003 starting issues & other issues
Old Oct 30, 2009 | 08:00 AM
dwarber's Avatar
Default 2003 starting issues & other issues
I have a 2003 escape and for the last couple of months I have been have issues starting on occasion. About every month or so I went to start the car and it was like I had a dead battery (click click click, when turning the ignition) I would get a jump start and there would be no problems for about a month. Then the same issue... jump start once, good for about a month. This last time I jump started it I lost interior lighting, radio and automatic door locks with the fob. Also, on occasion, while idleing dash indicator lights would come on until I hit the gas. Can someone please help. I want to say alternator but I can drive around for an entire day without losing any charge to the battery... (don't want to spend the money on the alternator if all I have to do is clean some wiring)
Old Nov 4, 2009 | 12:12 PM
fyrefly13's Avatar
Funny you should mention this problem! I know very little about cars, but mine just died, (I'm going to be posting my issue in a few minutes) and my dad suggested it might be the BCM (Body Control Module.) I'm not sure this is the issue for MY Escape, but it might be for yours. I did some research on it after my dad suggested it, and everything you describe sounds like the BCM. I had the click click click issue a few times after I got what I thought was bad gas, and like yours, a simple jump would do the trick. We thought it was the battery and replaced it (which I'm almost sorry I did now) and, while I hadn't had a problem since then, everyonce in a while it would get sluggish, like it was going to die. Well, last weekend it finally did. But I hadn't had the other issues that you had. How long between it starting the battery problem and you losing the lights, etc? My so-called battery problem started in August.
Old May 4, 2025 | 11:31 AM
The first thing I would suggest is to have the alternator output checked. Suspect there may be a problem involving that output..
Output is determined by what info gets back to PCM. Until we know where we stand there, cannot suggest anything worthwhile.
Output is measured in Amperes, NOT voltage readings, unless you are doing voltage drop testing.
What else might we be of any assistance ?
zombieoverlord
Jul 30, 2022 05:28 AM
gohokies123
Apr 3, 2020 07:26 AM
jrube
Apr 1, 2015 02:32 PM
benniewi
Aug 24, 2013 09:40 PM
oilers1967
Mar 7, 2007 11:44 AM
