Go Back   Ford Forum - Enthusiast Forums for Ford Owners > Past Ford Models > Ford Escort
Welcome to Ford Forum!
Welcome to Ford Forum,
Old 10-31-2009, 01:38 PM
khushsk khushsk is offline
Unhappy 2002 Escort ZX2
Hi
First, thanks in advance for any replies.
My headlights flicker, and every time I turn on the right turn signal, my headlights go off. Also, my headlights seem to flicker at times, and I have to flick the switch around a bit to get it on again.
I'm guessing my headlight switch is screwed up. I want to replace it myself, and I have the switch. But I have no idea how to do it.
Help, please?
(One of the estimates I got is $150, and I am a poor student in college)
Old 10-31-2009, 08:37 PM
FordMan59 FordMan59 is offline
Quote:
Originally Posted by khushsk View Post
Hi
Help, please?
It's probably the multi function switch turn signal/dimmer switch. I don't know what model your car is, but to replace it on my '88 Escort all you have to do is remove the cover on the steering column which exposes the switch. There's then 2 or 3 torx head screws that have to be removed, then just unplug it and put the new one in and replace the cover.
Old 11-01-2009, 02:55 AM
Quote:
Thanks! Mine's an '02 Escort ZX2. The mechanic we took it to today said it will be complicated because it has an SRS airbag. Not sure why it should be more complicated just because of SRS, but is that true?
Old 11-01-2009, 05:04 PM
Here's the instructions for '98-'99 ZX-2's according to my Chilton's manual. My manual doesn't go beyond '99, but the proceedure would probably be the same.
Caution: Some models covered by this manual are equipped with a Supplemental Restraint System (SRS) which uses an air bag. Whenever working near any of the SRS components, such as the impact sensors, the air bag module, steering column and instrument panel, disable the SRS by disconnecting the negative battery cable.
(Removal)
1. On 1998-1999 coupe models, remover the steering wheel according to the appropriate proceedure.
2. Place tape on the air bag sliding contact to prevent it from moving.
3. Unfasten the lower steering column cover retaining screws and remove the upper and lower column covers.
4. Remove the combination switch retaining screws.
5. Unplug the combination switch electrical connectors.
6. Remove the switch.
(Installation)
7. Place the combination switch into position.
8. Attach the switch electrical connectors.
9. Install the switch retaining screws and tighten securely.
10. Install steering column covers and tighten the screws securely.
11. Remove the tape from the air bag sliding contact.
12. Install steering wheel and a new retaining bolt.
13. Connect the negative battery cable.
14. Confirm operational status of the air bag system by turning the ignition key to the run position and visually monitoring the air bag indicator lamp in the instrument cluster. The indicator lamp should illuminate for approximately 6 seconds and then turn off. If the indicator lamp does not illuminate, stays on, or flashes at any time, a fault has been detected by the air bag diagnostic monitor.
15. Check all combination switch functions for proper operation.
Tags
2000, 2002escort, 98, air, airbag, bag, codes, column, cover, e150how, ford, headlight, location, module, replace, steering, switch, zx2
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
