99 Ranger 2wd front end vibration
Old Nov 10, 2009 | 06:34 PM
FricknRanger's Avatar
Default 99 Ranger 2wd front end vibration
My 99 Ranger 2WD w/ 160,000 miles is experiencing a vibration in the front end at about 60 to 70 MPH. I have installed new brakes/rotors/bearings on the front end, brakes were due. It has new tires, BFG Longtrail T/A, as of a month ago. My local mechanic has given me a scenario that if I turned the front end by hand (while on jacks) without using the steering wheel that the rack & pinion would become airbound and this causes a vibration during speeds above 50 mph. He said as I drive it the air would work it's way out. It has been sometime since I performed the brake job, and I still have a vibration.
I'm waiting to get the truck from the body shop as a deer made a hood ornament of itself. When I do, I'm going through the front end and checking all steering components for wear and such.
Any suggestions as to where/what is causing the vibration would be appreciated. PS> I am taking it back to the tire shop to check the wheel balance just in case.
Thanks, FR
Old Nov 30, 2009 | 10:18 PM
go2fast's Avatar
I'd start by re-balancing (or rotating) the tires. If that doesn't help, it's time to check the ball joints, bushings, and tie rods. Bad shocks can cause that too. A bad rack is less likely, but also possible. If it's all original, it's probably time for some parts.
Old Dec 2, 2009 | 12:51 AM
Bullitt94's Avatar
I agree with go2fast, rotating tires is a good start. It eliminates the chance you may have lost a tire weight. Put both fronts in the back and both backs in the front. If the shake moves to the back, you have found the culprit.
oregonn8v
Jul 2, 2009 08:00 AM
pixleyyy
Apr 1, 2007 10:12 PM
chaud
Feb 19, 2006 01:17 AM
flynhigher
Feb 10, 2006 08:59 PM
nicholsmf
Oct 29, 2005 08:03 PM
