Calling all Ford Techs.
Old Nov 10, 2009 | 09:50 PM
dvic1973's Avatar
Default Calling all Ford Techs.
I have a 1999 Ford Explorer XLT that will not start. I replaced the fuel pump and filter, checked the relays and fuses. No fuel pressure coming from the shrader valve. Truck will start when I spray starting fluid in the intake. It starts and runs but then cuts off when its gone. Could it possibly be the cam shaft position sensor, crank shaft position sensor, or the oil pressure switch? I checked the inertia switch also and its not tricked.
Old Nov 10, 2009 | 11:15 PM
Do you hear the pump run when the starter is bumped, or the key is cycled On/Off? Is there voltage at the inertia switch? Also, what engine?
chadwoody1234
May 8, 2011 07:46 AM
TRH
Aug 30, 2007 02:45 PM
AutoWeek
Jun 29, 2007 08:39 AM
vince69007
Jan 27, 2007 04:06 AM
masterexploder
Oct 4, 2006 10:49 PM
