Ford Fiesta, Gears not working, broken Gear Box??? HELP!
Old Sep 26, 2005 | 10:03 AM
flashrulez's Avatar
Default Ford Fiesta, Gears not working, broken Gear Box??? HELP!
well today i finally got my test and the freedom ive wanted. However going down a 60MPH straight and trying to gain speed i couldnt get it into third gear. From then after the gear stick has been extremely tight, making it nearly impossible to put the stick into gear.
It is able to be put into gear whent he engion is off, but as soon as i turn on the engion i have no luck and the problem comes back. It isnt the clutch as when i try to change the gears im not stalling
When i try and get the car into it feels like the whole care moves to one side. Another thing is when its in first gear (after starting it in in first) and having my foot on the clutch, the car moves, like it would if it was in second without the clutch down.
Is this signs of a broken gear box??
Please help!
Thanks,
Chris
Old Sep 26, 2005 | 07:50 PM
Default RE: Ford Fiesta, Gears not working, broken Gear Box??? HELP!
may have a leak in cluth master cylinder or slave cylinder. when you loose your brake fuild the clutch stops working and you have simtoms you got
Old Sep 27, 2005 | 12:53 AM
torres97t's Avatar
i had a 89 acura integra that had a shift link rod that broke in half and did the same; wouldn't engage gears when on and would engage when on! im not sure if your ride has a link rod look underneath car you should see 2 poles hanging or a pole bent! that rod cost me $25 and i replaced myself thou was a paine in the kchishkas but i fixed it good luck!
trev0006
Jun 5, 2013 11:50 AM
afer hours
May 17, 2013 08:17 AM
dilyb
Jun 18, 2012 12:49 PM
projectprerunner
Dec 27, 2007 04:06 PM
