2004 f350 diesel need feedback asap
Old Jan 10, 2010 | 05:45 PM
shanes 04's Avatar
Default 2004 f350 diesel need feedback asap
my truck stalled yesterday and rolled to a stop. I tried restarting it but it just cranks over and over no start. i just had the fuel pump replaced and it's been a bit slow to warm up. but running pretty well other than that. The dealer says maybe an oil pressure issue and I just had it in there a couple weeks ago for a whole month and a half because their mechanic doesn't know jack about powerstrokes please help
Old Jan 10, 2010 | 05:59 PM
heerdez's Avatar
my friend charge up those battery well and throw in little starting fluid while cranking it up youll be suprise you may think iam crazy i dont use much starting fluid but i spray in wd40 spray to get it kicking but battery must be fukky charge ,,dont start there filter som where in the chassis area find it opened it and let the water from your diezal to drain till u see come out clean Gooddd luck
Old Jan 10, 2010 | 07:28 PM
shanes 04's Avatar
it cranks fine so you thyink its a fuel issue
Old Jan 11, 2010 | 04:29 AM
heerdez's Avatar
yessss i work around many trucks any myself had this issue
Old Jan 13, 2010 | 02:35 PM
shanes 04's Avatar
hey thanks, turns out the sending unit that I got from the junk yard and had the dealer install for me was reading wrong and at a quarter tank it was actually empty. filled it up and it starts. however when it starts it seems weak and then speeds up to a normal idle. why is that
Old Jan 14, 2010 | 03:58 AM
heerdez's Avatar
It is normal Good Luck
nktidwel
Jun 5, 2010 02:56 AM
specwar64
Apr 4, 2008 10:32 AM
SuperFord73
Apr 26, 2007 07:59 PM
Silverrr
Dec 19, 2006 10:29 PM
TWOLVES21
May 9, 2005 04:51 PM
