1994 tempo noise
Old Oct 4, 2005 | 04:12 PM
mccall33's Avatar
Default 1994 tempo noise
My 1994 tempo makes a whining noise when I turn it off. It might be doing it when it is running but I cannot hear it. I suspect some kind of vacuum leak or perhaps some carbon build up. It has 155,000 miles but runs fine. Air filter is fine also. Sounds like it is coming from the throttle area, but not sure. Any ideas?
Old May 13, 2008 | 12:28 AM
Default RE: 1994 tempo noise
Sounds like a vacuum leak that winds down after you shut it off. Or could be radiator/engine overheat (fan not turning on and sensor not reading it or fluctuating disguise -(car cools and reads normal when in motion (air pushing in radiator cools it) but heats up if idling and not moving for 5 minutes to a half hour). The whining can be normal antifreeze blow-off from the pressure cap (only holds certain lbs. of pressure) too (if you fill the radiator over full repeatedly).
mikco5024
Mar 3, 2012 05:29 AM
tekvideo
Sep 4, 2011 05:37 AM
CarGirl
Oct 13, 2009 08:19 AM
sellis
May 13, 2008 12:08 AM
sellis
May 20, 2005 02:31 PM
