1999 24 valve
Old Apr 4, 2010 | 08:42 AM
NH_USA's Avatar
Default 1999 24 valve
Got a service engine soon light and the code said it was the EGR valve. I reset it and the light stayed off but I'm thinking about changing the valve anyway ..
Is it an easy job?
Old Apr 4, 2010 | 09:38 AM
way2old's Avatar
What was the excat code number? Most of the time the valve is not the problem. If it is a P0401 that usually is the DPFE or ports clogged under the valve.
Old Apr 12, 2010 | 11:33 AM
NH_USA's Avatar
Thanks for the reply -- I don't remember which code it was but now have another chance to get it because the light returned last night. The vehicle has had very little use (1999 with only 48 K miles)
A few more questions..
What is DPFE?
How do you check it?
How hard is it to remove the valve and clean the ports?
Old Apr 12, 2010 | 06:19 PM
way2old's Avatar
The code is more than likely a P0401. The DPFE Is the Delta Pressure Feedback EGR sensor. It takes the exhaust pressure and converts it to a reading the computer can read. Go to www.autozone.com and search the DPFE and it should tell how to rest it. The site is athe same information as Alldata, just a little less in depth. There is a picture below. The valve is straight forward removal. The ports are on the engine side. Good luck.
jenmes70
Jul 29, 2013 07:17 PM
Des
Dec 2, 2008 11:17 AM
localtoys73
Oct 20, 2005 11:50 PM
DAbbe1013
Sep 11, 2005 12:19 AM
uno_94
Jul 25, 2005 04:54 PM
