bearing problem?
Old Apr 30, 2010 | 09:25 AM
raj828's Avatar
Default bearing problem?
i have an '04 AWD, i have noticed for the past week that the rear wheel on the driver side had been smelling a burn brake pad. i had the brake pads change lately and checked if it was acting up weird but seems ok, the calipers are working fine also. one time i just came home and had the burnt smell again and this time the wheel was really hot. i had it lifted and checked, there is a limited play on that wheel compared to the other side. so i was thinking the ABS might be the problem... lately i have been ignoring the light on ABS cause it comes and goes same with the 4x4 high light...
anyone have any suggestions?
thanks
Old May 10, 2010 | 11:05 AM
Sounds like you have a caliper hanging on you and not totally releasing the pads like it should. This will cause excessive heat,the smell of break lining and cook the bearing grease.
Old Jul 19, 2010 | 12:51 PM
raj828's Avatar
i have change the old calipers which were very rusty and noticed also that they wouldn't budge/retract as a new/refurbished one...
solution : change the calipers and if the brake pads are burnt change them also...
thanks...
hardrock96
Feb 14, 2022 05:51 AM
penet05
Oct 17, 2014 03:16 AM
ranchhorse
Dec 10, 2005 04:40 PM
roguespirit
Sep 28, 2005 07:17 PM
sprdty21921
Aug 28, 2005 04:15 AM
