04 f150 no crank
Old May 6, 2010 | 06:34 AM
agent008's Avatar
Default 04 f150 no crank
I have a 04 f150 with the 5.4 that just shut off like the key was turned off, the only thing that runs when the key is on is the fuel pump, i've checked the fuseable link & the hotwire on the starter & both are in good shape, I also have no power at the starter on the hot wire (crank signal)
any body have any ideas as to where i should be looking?
Old May 11, 2010 | 06:14 AM
agent008's Avatar
ended up being the fuel pump module shutting everything down, so if you have similar issues you know where to look
mudgunner1
Feb 12, 2015 05:59 AM
Bigpun
Mar 24, 2014 07:49 PM
KellyMiller
Sep 24, 2005 11:59 PM
ladyferricher
May 6, 2004 01:44 PM
