Engine Problem
Old Oct 7, 2005 | 01:44 PM
bwilson3's Avatar
Default Engine Problem
I have a 2000 Focus. It has been making a roaring sound on starting for about a year which disappears upon engine warming. Mechanics have not been able to diagnose the problem. Sound suddenly became worse and engine became very rough and could not maintain idle. Anyone with any ideas on what is going on?
Old Oct 11, 2005 | 02:10 PM
josser's Avatar
Default RE: Engine Problem
have the checked the starter! if the starter motor spline is not retracting completely after starting the car it can grind with the flywheel making and awful sound!
also have them check the EGR valve, and all the sensors!
Old Jan 9, 2006 | 08:04 PM
irishghost999's Avatar
I am a Ford Certified Tech from Canada, and I had one last week with that same concern. I found it was a faulty a/c clutch. It may not be the same concern. If it happens again switch the a/c on or off and see if the noise changes. If it does, you have pin pointed the problum.
amcole82
Feb 11, 2011 08:18 AM
jamesmanning
Nov 3, 2010 10:49 AM
Bill in Tampa
Apr 27, 2008 09:30 PM
bmwrocks03
Apr 21, 2008 09:29 PM
daveranger
May 24, 2007 12:56 PM
