Fuel pump no power & cant locate fuel pump relay 94 f250
Old May 23, 2010 | 02:40 AM
jozepy24's Avatar
Default Fuel pump no power & cant locate fuel pump relay 94 f250
I have a 94 F250 that just died when I hit a small speed bump. I found the inertia switch & its not poped so I check if I had any power to the inertia switch with light,, No power !! So I figure the relay is bad . I was told its in the Fuse box on left side of compart under hood . I change them all & still no power. Ive been told the relay is next to the master cylinder on the fire wall .. I cant seem to locate it . But if all the relays do work & still no power to inertia switch what could it be?? Please help It has the 4.9l 6 cyl Thank you all for your help
Old Jul 13, 2019 | 05:21 AM
HRAllen20's Avatar
Look in cab for fuse center on passenger side...I think that is where my husband and father in law found it. It is a non serviceable part on my 04 Expedition so we had to bypass it and once we did that, it started right up.
DogBreath
Nov 19, 2017 11:23 AM
fordman 46
Aug 23, 2015 08:23 AM
92needshelp
Mar 2, 2013 01:46 PM
ugly gremlin
Mar 25, 2012 09:22 AM
milkman48
Jan 28, 2012 05:41 PM
