f350 power steering/brake issue
Old Oct 8, 2005 | 10:02 PM
kamaleon's Avatar
Default f350 power steering/brake issue
Hi guys, im new here and desperate searching for a solution to a problem..
While relocating the Power Stearing cooler the system got air in it. I was told to raise the front wheels and stear from side to side, pump the brakes and add atf fluid if necesary.. I have done this many times and it has not solve a thing. When i turn the engine on and test the brakes, the p/s fluid foams up.
Can anyone offer a solution to this problem?? thanks guys!
Old Oct 8, 2005 | 10:07 PM
kamaleon's Avatar
Default RE: f350 power steering/brake issue
forgot to metion that its a 99.5 powerstroke
Old Jul 1, 2010 | 10:51 PM
fordjuny's Avatar
hows it going ford lovers i ran into a bit of a problem with my 83 ford f350 crew cab truck ,the previus owner installed a new brake master cylinder and i go to bleed it and the brakes all around squirt brake fluid but the peddle does not get any higher can someone help plz
Old Jul 2, 2010 | 04:56 AM
Check the rear brake self adjusters. Sounds like they aren't working. They have a tendency to corrode and freeze up. Also, you might try backing up several times and hitting the brake, this is the procedure to get the self adjusters to adjust the clearance if they aren't frozen or the adjuster arms or star wheels aren't worn. Don't remember if this vehicle has disc brakes in front. If it does, make sure the caliper slides aren't jammed with rust and grit so the calipers can't move and compensate for pad wear. Let me know how you make out. Thanks,,,,, hanky
Old Jul 2, 2010 | 05:02 AM
Did you have the engine running when you had it up off the ground?
The engine has to be running to circulate the P/S fluid when you turn the steering wheel from side to side. Be sure to keep the level full when you do this or you will just keep circulating air into the fluid. Let me know how you make out. Thanks,,,,,,,,hanky
Van Lover
Mar 23, 2013 07:23 PM
marktomes
Jan 2, 2012 07:33 AM
jaymzsun
Mar 10, 2011 08:13 PM
alwaysdutch
Apr 3, 2010 04:09 PM
Team Gauguin
Aug 19, 2008 12:58 AM
