Reversing Light Problem
Old Oct 9, 2005 | 12:20 PM
McHenry's Avatar
Default Reversing Light Problem
I have a 2002 Focus TDI and cannot get the reversing light to work
so far I have replaced the bulb checked the fuse and tried to locate the earth point to clean that up if it needs it but cannot track the wiring to the earth point
Does anyone know where the earth point is?
Also any suggestions as to what else to look at?
Mchenry
Old Oct 10, 2005 | 01:05 PM
McHenry's Avatar
Default RE: Reversing Light Problem
As an update to the above I have now checked the earth with a multimeter and that looks ok, also checked the power supply and thats showing 12 volts ok but does not have the power to light a low wattage bulb and that is too various earth points.
So it looks like I need to gain access to the reversing light switch
can anyone help with the location of this and an easy way to access it
Old Oct 10, 2005 | 05:52 PM
This switch might be part of the nuetral safety switch usually located on the transmission.
Old Oct 11, 2005 | 02:13 PM
josser's Avatar
where did you buy your focus! i'd love to have a TDI version
Old Oct 13, 2005 | 07:07 PM
McHenry's Avatar
cctxfish
Thanks for that I will try and get to it this weekend
josser
got it from Fords of Winsford nearly two years ago
Old Dec 20, 2005 | 04:28 PM
edaddik's Avatar
look for your tranny and check the reverse light switch(it's like a connector plug) it's connected in the transmission disconnect it and check it with a voltometer. if it's defective replace it.
neil 54
Sep 11, 2010 01:56 PM
Zapman
Feb 16, 2009 06:29 PM
JohnnyFord
Sep 12, 2007 11:18 AM
