2003 ford sports trac, turns over but won't start sometimes.
Old Jun 20, 2010 | 12:11 PM
basenc8's Avatar
Default 2003 ford sports trac, turns over but won't start sometimes.
basenc8,
Old Jun 21, 2010 | 04:00 PM
More info please? Is the outside temp hot, cold? Is the engine hot, cold? Is it dry, wet outside? What does it do when it doesn't start? Does it sputter and try to fire, do you smell fuel?
Old Jul 11, 2010 | 10:10 PM
basenc8's Avatar
Hi! common sense, the outside temp, is hot, it is like I have to let it cool down for it to start again. Tried to connect it to the obd2 meter and nothing shows up, no code nothing, but when it starts it will keep starting untill one day it does it again does not start. Tried to check the fuses all is fine, relays all is fine change fuel filter,reset the button on the passenger side still won't start, altough sometimes I don't hear the fuel pump run for before it start or do you have to hear the fuel pump start every time you start the car. I think if your fuel lines are primed you won't hear the fuel pump run all the time. I am almost out of patience with this problem for it happens everywhere and anytime without any warnning.Thank for your reply hope I can pickup alot from it to fix it, thanks again so much.
ShibbyX13
Dec 3, 2015 03:22 PM
rodneylynn1977
Nov 15, 2008 08:41 AM
bwood
May 21, 2007 12:28 PM
bwood
May 21, 2007 12:14 PM
fordluver
Apr 24, 2006 11:46 PM
