1997 F-150 Brakes
Old Jun 20, 2010 | 12:15 PM
fordtruck1's Avatar
Default 1997 F-150 Brakes
Just replaced the front rotors, calipers, pads and rotor frames on my 1997 F-150 4x4. Pretty routine, with no surprises. Bled all four corners according to the procedure in my Haynes manual. Had good brake pedal pressure while bleeding, but absolutely none with the engine running. Decided it had to be the master cylinder, so I replaced that, after bench-bleeding according to instructions. Still no pedal pressure with the engine running. Goes straight tot he floor every time. Looks like my truck has rear-wheel anti-lock brakes rather than the all-wheel version, and I looked all over for a bleeder valve on that line, but no luck. At this point, I can't even drive it to the shop. Any ideas?
Old Jun 21, 2010 | 09:19 AM
Bullitt94's Avatar
Your sure you don't have a leak somewhere? Maybe a connection that didn't get tightened properly?
bootpond
Dec 30, 2009 05:59 AM
trucklover
Jan 12, 2009 10:17 AM
farmboy1
Jan 28, 2007 12:48 AM
sincitykustomz
Dec 11, 2006 12:37 AM
sincitykustomz
